Stalling 65
65fast
I have determined that my 65 has got a vacuum leak somewhere, by screwing the mixuture screw all the way in and it still runs. Any one know how to pinpoint a vacuum leak? I was going to spray some carb cleaner around the base of the carb with it running, until the can said dont spray with ignition on.
Thanks
----I also have a coil wire hanging by a few threads on the negative post, so I am not sure if this is it or not becaus the car will run at higher rpm, and then stall at idle.
