Hello all.
I am new here and had a couple of questions.
Many, many years ago. I bought a 66 'stang as a teenager (in the late 80's). It was a 200 cid coupe and like all teens, I wanted to supe it up. Well, back then, there wasn't much info or places to get parts, but I started. Well, college and a marrage caused me to put the car away 2/3 of the way finished and now with a little money and one less wife I am planning on starting again.
Sorry about the background, here are the questions.
When I originally added the Clifford dual outlet header, my buddy who custom made the exhaust had to cut the end flanges off of the header pipes because they hung to low to the ground. Instead, he welded the header directly to the exhaust. Has anyone else had this problem? Has this been corrected in more current versions of their headers?
Secondly, I purchased a Weber 2bbl adapter and the Weber 2bbl carb. When I put the adapter on the intake and the carb on the adapter it was not sitting sqaure with the block it was turned slightly. I ended up having a adapter made to sit between the intake and the Clifford adapter, but then the carb had hood clearance issues. Are there different adapters for the Weber carb?
Lastly, I know the 6 cylinder Mustangs had a smaller (7 1/2'' ?) rear-end with integral gears. If I remember right the ratio is 2.73:1. Is there another read-end with a better ratio that is a DIRECT replacement or a way to change the gears?
Thanks!
Thanks!
