**1968 200ci engine with Pacemaker dual outlet header, dual exhaust, Holley 5200 2bbl carb, Pertronix electronic ignition**
Hi,
I was able to take the Mustang to my old high school for a show today, and as usual, it stumbled when accelerating. It does not seem to do it as bad in the higher RPM range. A few minutes into the drive home, the engine did not stumble much at all but not all of the power was there. It does not seem like that would be a timing issue. If it was, wouldn't the problem be continuous? I just redid the carburetor and carburetor adapter mounting gaskets, and this time I used gasket sealer. I thought that might haved solved the problem if it was a vacuum leak. No good.
I have my spark plugs gapped to .050", which is what many I6ers run them at, correct?
What are your thoughts on it being the accelerator pump?
Thank you,
Justin
P.S. I have four (yes, four
) pretty girls who want a ride in the Mustang but I cannot do that with such poor performance.
Hi,
Thank you,
Justin
