George66Falcon
Good evening, gents!
I've been working on and off on a supercharged 200 for awhile now. I made the mistake of using vacuum caps to cover the vacuum ports instead of the carb box instead of mechanically sealing them (I'll be tapping the ports and running a screw with sealant into each of them) and went lean under throttle. I broke a bunch of rings, bent a few connecting rods, and broke a piston skirt -- thankfully the block/cam/head are OK. I've picked up a set of forged connecting rods, but now I'm thinking it's time to consider some forged pistons as well.
My concern is spending a lot of money for something that won't be right. I fed my engine's specs into Grok and it came back with a reccomendation of a 20cc dished piston to lower the CR to 8:1. I'm running the 250 2v head with an m122 blower, water-to-air intercooling, meth/water injection, and 20lbs of boost.
Do you think the recommended pistons are appropriate? I appreciate your feedback!
