8) when trying to figure how much power you will make with a super, or turbocharger, you can follow this rule of thumb. 15psi(ok 14.7 to be exact) boost pressure will double the horsepower output of any engine. cut that in half to 7.5psi and you pick up 50% horsepower gain. 5 psi would be like 33%. remember this is based on what power the engine is making now, so if your engine was making 100hp normally aspirated, then with 15psi boost, it would make 200hp, 7.5psi boost 150hp, 5psi boost 133hp. again these are rough numbers to give you an idea of what to expect when installing forced induction.
