Supercharger kit
Ford has run a family of engines during its tenure in Australia, V8’s have been available since XR Fairmont and XR GT, they dropped the V8 with the efi six as the "biggest engine” since there errant ways they re-introduced the V8 in EB Falcons, the best offering was a Handbuilt 347 stroker, with the way the OHC and Turbo OHC scene is going yes less and less people will bother with older log’s and crossflow, but any engine can be a good one, there will now be blower manifolds for a range of engines, efi engines converted to carbie in the OHC family and at least a company is making and developing the ford six, i should add they are also doing holden and valiant slant sixes. Its a raging debate about this and that, my fiends roller crossflow has a 279@50, over 700 thou lift cam and runs triple 50mm webers, others similar are in the low 11’s its only a matter of months and we will have a full bodied street car in Australia running 10’s aspirated in the old crossflow. Its is my theory that a log head or 2v head or even alloy head aspirated can do times in the high elevens aspirated, its called development.
gb500":25b514ub said:
...ok thanks ....
i gleaned you havent sold any
but i am still confused : do these engines exist?
- you talk about one supercharged 250 'being made' since 2001 ?
is it completed ? - and dyno'd?
- as you state hp figures in your sig ?
put up some pics and dyno charts
I won't put up dyno charts until I've made my first sale.
No flywheel hp figures, but over 450 hp net isn't a problem with either combination even with an iron non cross flow log. The trick has been to run a very radical cam profile which has very little load stress.
I have four blocks in my basement. I got independent verification that with the small valves and planned mods I could get an engine with with about 252 hp and 270-lb-ft with the required roller cam normally aspirated. The intercooled figure of 480 hp under 16 pounds boost came up, so I had to peal back the boost to reach my target hp. I've got the triple carb style intake manifold all sorted, which effectively high ports the stock log head.
The liners were easy, and now its just the base tune, with fit up early next year. Then searched the turbo and superchargers that did the job. I have access to just a chassis dyno here in Dunedin.
xctasy":25b514ub said:
The truth is exactly as David Ford said in Australia in 1982 when the EFI 4.1 replaced the 4.9 and 5.8 Cleveland. "There are very few V8 die-hards around, and they will come around in time". Its 31 years on, and he was right!
and yet 9 years later ford australia reintroduced the V8 (5.0l wndsor)cause they were losing sales with only a 4.1 six
The truth is that David Ford was right... the V8 market is tiny compared to the US, and I guess it was Ford Australia's Jac Nasser who only signed off on the 5.0 for the EB and XR8, Fairmont/Fairlane and LTD and GT because the Falcon needed halo models. The single and twin turbo AIT Turbo Falcon's would have been more economical options than imported V8's, and Fords traditional resistance to Diesels and four cylinder turbos and its reliance on contracted out supply for Aussie made autos deep sixed those options. Ford didn't get the help it needed from Borg Warner, so it should have instantly imported Japanese Toyo Kogyo, Jatco or US transmissions when proper T5 and Asian Warner 4 speeds weren't forthcoming from Borg Warner Australia. Ford Australia had the market and supply contract numbers to totally make the economics work, it was from 1980 to 1985, the most profitable wing of Ford worldwide, bar none. What the heck happened? They went soft of specialty product, when Holden was letting Brockie go feral. Phase Autos with there Phase 5 and 6's and AIT couldn't make the economics work, but Ford Australia would have with just the sales of alloy A3 heads, SVO blocks and proper US gareboxes. Ford Australia had Hondas alloy head capacity, a consignment of orders for world wide De Tomaso sales. They after all were making them. Wheels and Street Machines V8's Till 98 compaigner Phil Scott commented on this lamentable state of Turbo Falcon affairs when Ford wouldn't cover Turbo Falcon, Fairmont, Fairlane and LTD transmission warranties on AIT's roller converted BW40 and non world class T5's. THATS WHAT KILLED THE FALCON TURBO IN 1985!!!
I'm very angry that when every Ford post had the best gearboxes and turbo engines around in 1985, Ford Australia were busy scrapping there production tooling and saying no to imported Windsor 5.0's and AOD's for there 164 hp 4.1 EFI's. It was a disgrace. You wouldn't play cricket without a spin bowler, would you? An XF was a cool bit of kit, but without a 250 hp engine, an Automatic Overdrive and an AIT EFI turbo, it wasn't going to set the world on fire like the 1979 to 1983 XD to XE's did. The technological advance Australia stopped when the three years of 164 hp 4.1's failed to get added to by proper gearboxes and performance engines.
When I studied what Ford US did with the SVO engineered Escort EXP and Mustang and Turbo Coupe engines in 1983, its a crime that David Ingall had to buy an aftermarket US piggy back program to do what Ford Australia could have done on every 268 hp T3 60 Turbo EFI 4.1. A Brock Commodore wouldn't see which way a Falcon turbo went if Ford Australia had given the performance maket support on replacing the 4.9 and 5.8 with proper fortified 4.1's. The EEC IV Fords were the most reliable engines Ford ever made, despite the technological advance.
Historic V8 sales were never much chop, even hot six sales were exceptionally low in the 250 2V era, less than the 351C 4-bbl. From an economic point of view, Ford Australia could have pumped up V8 sales like Holden did from 1969 to 1998, by copying Holden's lead on having less capacity. They had 173, 202, 253, 308 and then 350 engines, the right mix. Ford Australia could have had shallower, lighter 3.1 and 3.6 base six engines, then mandatory 255, 302 and then 351 variants on the same basic one size fits all engine block. The US 255 Windsor just used Falcon 200 pistons, and stock 302 internals, as did the Aussie 253 compared to its 308 mates. So Australia could have slapped some 3.68" pistons into the 302C, and some smaller X-flow 1.8 intakes and 1.5 exhast's in the 57 cc close chamber head, and it would have killed every 245 and 265 Hemi. And every 2 and 4-bbl 253.
Ford Australia had the market, and then reverse engineered its demise. Max Gransden even admitted it in 1985, but the demsire of the Cleveland was made in Dearborn by Henry Ford II in 1979, not Australia. Ultimately, the 302C out numbers the 351C 5 to 1 in survival and numbers made, but the I6 in 200 and 250 capacities out numbers the V8 well over 10 to 1. Holden's Warrick Bryce let slip when he discussed the historical numbers when the 304 EFI came out in 1988...that historically, V8 sales were about 20% of H or V car sales, or about 10 000 vehicles max. Ford found the same thing, so it could tricked feed the luxobarges and GT, GXL's and Ghias with 302 and 351's for 12 years with nil investment cost. Chrysler had the best V8's in the world, bar none, a tuned LA 340 or 440 Big block kills any stock small or big block Ford, but they pumped up six cylinder sales to suit the market.
In summary, a junkyard dog 200 250 block of any denomination is cheaper to get, easier to rework, and if its marketed right, eclipses even a melodical Cleveland. It was held back by Ford because of the excellence of it top line Windsoe and Cleveland V8'S. But it doesn't suffer as much from thin wall blocks, head cracking and coreshift like our Aussie Cleveland did, and the front block cracks aren't a major to fix. The real issue is Ford Australia did the numbers on the turbo six in 1984, and, service backup, insurance wise, and durability wise, it backed out because of the cost of getting it to work with the busted a$$ Borg Warner 40 trans. All it had to do was make a 2/3rds SBF low mount block, and job done. The crime was they had all the techonology, still do, and they can't figure on what grass roots modifiers really like to do.
well said, you only have to look at what they were doing to ford 144’s in 1960 to get an idea of what can now be achieved with newer technology, nicer carbs and blowers.
extasy - i am so confused - you dont seem to anwser straight.
just a yes or no will do as to wether you have completed and tested one of these turbod engines
why is the dyno chart a secret?
it ususally one ofthe things people like to show when they have stout engines
how about some pics then- of the head/manifold?
No pictures yet.
No, I haven't run a complete engine yet.
This is in a post about another Supercharger kit from another supplier, on a website affiliated with other kits which don't have full dyno runs at all.
For what its worth
No, I haven't got an SAE net horsepower engine dynamometer run to show.
What I do claim to have is are two 425 hp 4.1 liter engine combinations, and a price, 7995 US, locked in.
In the past in xec.info, I've advertised it all, but I removed the adverts because I don't spin doctor what I haven't got.
Programs exist that can estimate the output within 10% of a given combo, which others can use.
I've given my details on what the engine is, what the supplied parts are, except exactly what the cam is, how the factory EEC V system is recalibrated, how the exhast works exactly, and what the 6VHO intake is exactly and what head cfm flow rates are at various lifts are. The dyno chart anyone can work out from what I've given. The cam supplier is Kelford Camtech, who have helped me out since 1993 on six cylinder engine simulations, and the heads are imported from the US, but the profile of the ports and the design of the intake and exhast profiles are mine, with local input from a well respected Dunedin engine builder who I've used since 1988.
It's like this...once you lock in the dyno figures for sale, a whole lot of process stuff has to then be done. I'm not going to fabricate or say yes to things I don't have. Especially not a dyno chart. That's why my company takes out liability insurance each month, because things happen and people sometimes take exceptions to not being able to back up the words with deeds.
Well said mate, the whole world is up its own ass with power figures, i see guys over here, cant get there cars down the track and blame track owners for poor prep, its all a copout and a penis measuring comp, i am after a blown motor that is all, power is secondary, being able to drive the car and have fun, run a number etc, i am starting the build this week, firtst off is my big brake kit for the front end, new upper control arm’s and Calvert 90/10’s, i have all this minus the shocks in the garage but need time to put it on, so order the shocks on Monday, next will be the diff, billet axled borg warner 78 series 4 pinion LSD with alloy hat, once again i have some of the gear here on hand, and adjustable Calvert shocks, as you can tell i am building other components while waiting for the kit to be finished. This way i test each bit as it goes in, i also have a line locker and need to upgrade the electrical. once the motor is out i am bare metalling the engine bay, welding up all the holes, new 2 pack paint, i have been buying bits and pieces for a while now, missed out on some stuff like a NOS Edelbrock Tappet Cover that went for 400 bucks, i am going auto and need a Wilwood master cylinder sorted out so the bay gets done when i no longer need the slave cylinder hole and have the brakes sorted, as you can see its a process.
maybe we need to photograph all our good bits so we can get critiqued, i have a nice stallie and bell housing sitting there, all my brand new brakes and callipers, powder coated stub axles and late model upper control arms etc etc,
mike1157":36nrl980 said:
I'd imagine that that "kit" is way more than 2k to buy.
The 174 version is what is normally slotted for the SBF here in the states. Not a very popular power adder from what I've seen, even on a V-8. The Weiand advertised power gain is 25-40% over stock. (Stock 5.0's being somewhere in the 200 HP range, that means that the bigger 174 S/C will only net an additional 80 HP.) And that power gain is from a blower capable of supporting an additional 30+ C.I. rated by volume. The little 142 may make 40-50 HP over driven for all it's worth.
This is all w/o ever having the benefit of an aftercooler, as there is just no way to do that when the blowere is sitting right on top of the intake, and the boost generated by a roots blowers is hot. In this ones case, all that heat conductive aluminum sitting directly north of the exhaust. I'd bet the charge temps are well north of 250 degrees.
A standard Centrifugal S/C mounted on the opposite side of the engine, ( or a turbo) would be a much better choice, (and investment) than that one I'd say.
may B good for the 240/300 then?
