AbandonedBronco
Hi all,
I have a 1981 Ford Bronco with a 4bbl carburetor on it. I enjoy tuning it, and love the power over stock, but no matter how much I tinker with it, I can never get it perfect. The better gas mileage I tune it to get, the less acceleration and more "stumbles" it has, etc. etc. etc.
The more I think about it, the more I love the idea of fuel injecting it and tweaking and tuning my own fuel and ignition curves with a computer that does what I tell it to.
On that note, the two options I have before me are keeping my 4bbl intake and installing a GM TBI, or pulling the stock EFI intake off of a 4.9 and using that. (I have no intention of using the stock EFI computer, just the intake, as I want to be able to use different cams and such, as well as tuning it myself.)
I'm planning on installing a MegaSquirt setup or the like.
The bonuses I can see to the TBI are:
Already have the intake.
Keeps a "stock" look (as much stock look as there is with a 4bbl on there).
Takes up much less space under the hood.
Ease of working on the engine, access to the valve cover, etc.
Simpler overall.
Bonuses to the EFI setup.
Better fuel distribution (a dedicated injector for each cylinder).
Better fuel atomization (air/fuel mixes at the cylinder instead of at the throttle body).
I don't care about peak power all that much, so if I can get to 180hp with the TBI and 200hp with the stock EFI setup, but I like the TBI more, 180hp is just fine with me.
Thoughts?
Simpler overall.
Thoughts?
		 I have a stock 94 F150 with the 4.9 EFI before that also had a number of the Carbed 240 & 300's trucks. Worked with a number of Ford and GM TBI car's and trucks too they are quite good. But the winner to me is the 4.9 EFI setup it gives you the most bottom end torque for pulling and very good economy. Good luck in your build, I think you will be quite pleased with either system.
