There is no such thing as a stupid question. I'll answer your questions the best that I can. I am sure there are others who know a lot more than I.
1.Where can i get a Simple Digital System from?
SDS has a web site. Do a search for
Simple Digital Systems.
2. I dont really know the setup of TBI so if someone has a diagram to show how it works ?
TBI (Throttle Body Injection) is basically an electronic carb. It has one or more injectors mounted in the throttle body. The fuel and air is mixed on the TB housing as does a carb. Port injection moves the injectors into the intake manifold near each intake port. The TB in a port injection set up simply meters air.
3.would it be possible to grab a throttle body of any vehicle and adapt an injector to the top of it to squirt fuel in?
If you get a TBI set up the injectors are already there.
4. Does the oxygen sensor act like a choke, or does it controll the leanness/richness of the mixture, or both?
The oxy sensor screws into a welded bung in the exhaust header pipe. It senses how much oxygen is in the exhaust and relays that info to the computer (ECM). It does not act as a choke. Cold mixture is dictated by ECM from info collected by the engine temp sensor.
5.Could u grind the intake log the same way u would for 2 single barrel carbs and attach 2 throttle bodies?
Yes
6. i suppose connecting the throttles would be just as difficult as with carbs?
Yes, but you also need to mount a throttle position sensor as well.
7. can u use the mechanical pump and just have a regulator attached to the fuel rail?
No. You must use an electric pump designed for FI. You must also install a return line. It isn't hard to do but there must be a place to connect it in the gas tank. DO NOT TRY TO WELD ONE IN YOURSELF. It is extremely dangerous to do so.
8. the biggest question is...are the benifits worth it?
It depends on your skill and/or $$$ level. Your engine will run cleaner, get better gas milage and will need less work to keep in top running form.
I hope this helps.
Mike A
