hey everyone i just aquired an 56k 200 i want to make the most out of it i have the 3x1bbl intake but only 1 carb. does anyone out there have any suggestions? thank you for all of your comments
I'm in same situation. I had some carbs and picked up some on E-Buy. look for Ford and Holleys or Webers to fit. Do a search on Offy setups and you will get lots of opinions. If you have one carb, get one to match and a bigger one for the center carb. You can block the outers to test the carbs before using in 3X setup. I ran a 2BBl center and blocked bad carbs outboard for a while - ran great!.
