I was just sitting around thinking about rods, pistons, stroke, and rod ratio wondering how to get a longer rod into a 200 and I had a thought.
Instead of having the pin go all the way through the piston would it be possible to keep the pin fully inside the piston, no external holes at all, and secure it onto the pin with something like tiny rod/main caps?
I was only wondering because if this was feasible at all then couldnt you almost put the pin AT the same distance from the top of the piston as the compression rings?
-ron
-ron
