Looking for thoughts on the computer's (stock in this case but otherwise also) ability to handle increased air flow by way of a larger TB. Is it able to compensate on it own without effecting drivability to point where a retune must be done. As in will the MAF tell it whats going on. Now I understand that this is all within an acceptable spectrum of operation but here's my idea.
Everything about the stock intake system (lower/upper/TB) is significantly restrictive. I've done some things to deal with the manifold portion of this but now it's time for the TB. I know that the 5.8 TB is an easy choice for larger but there's a difference in TPS range? So how about using 2 TB instead of 1 for something like a 4 barrel setup with them synchronized instead of progressive. I would imagine the sudden increase of Air flow from a progressive setup would "shock" the system but maybe not. If they were to open together from Idle to WOT and both be plumed through the single MAF and get sensor and idle air from only 1 TB and the other would just be an extra valve (no sensors) would it run decent? In theory that is?
Or just to make life easy is there a mustang style (single blade) TB with the correct or swappable electronics?
