Timing gear set for 250
63comet
Has anyone tried this set for the 250? I was just wondering, since we can't get a performance set for the 250, Yet. If so, how did it work out for you.
Timing Gear Drive Kit
Click on image to see enlarged view
Item#: NTP81014
Price: $117.99
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Additional Contents:aluminum cam shaft gear
steel crank shaft gear
I'm no expert but if that is a Napa number (ntp is or at least I think it is)then you are out of luck, Napa auto parts shows a gear set, but it is for a 240/300 big six, make sure to order the chain set, or if you want str8 up cam timing order one for a 69-71, I think those part numbers are S414 and S415 (napa) for the gears and a chain from 69 to 77 is all the same the early ones have a wider chain..... Walt
Thanks, your right, it is a Napa part, and I went there today and asked availability of this and they told me it was not available anywhere in the US or factory.
