Timing gears caution
78merKri6
Just ordered and received new gears as part of fresheningy my 250. Discovered that NAPA factory has defaulted to 72-up specs on cam gear, seems to me. The cam gear has casting no.S414 but no etched nos. When degreeing, it checks as old s446 gear does. They have changed the chain also---crank gear seems same.
So, unless you want your valve timing left to someone else who doesn't care, degree your cam and cut 3 or 4 keyways in crank gear for advancing. If careful, you may do so yourself with a hand file.
Wish I had bought Mike's set!! Would have cost less too.
Also had to grind thrust plate cap screws to clear gear hub. What's th' world coming to?
Keep on Inlining, use care, good luck.
Gary
Gary
8) unless classic inlines has a new timing set for the 250, the set he does have wont fit. as for the rest, pretty much all manufacturers are defaulting to the 72 and later gear sets for stock replacement timing chain sets. the aftermarket isnt.
Can you explain what you mean by Classic Inlines 250 timing set won't fit?! Bought one recently and am installing it as part of my '74 250 build. Specifically selected it because I wanted the earlier set with the not-retarded timing.
Bob the Builder
8) i didnt notice the mike had started selling timing sets for the 250. that is why i qualified my post.
