Mustang_Geezer
Anyone know a good weblink that has to do with setting up optimal timing??
The questions I was looking at was,
1.) Good base timing setting??
2.) Total degrees advance at what RPM's??
3.) Distributor advance spring changes??
I just installed my MSD 6A today and fiddled around with my plug gaps. It seems to like around .048 gap the best. Anything over .055 and it starts to miss and a couple of my electrodes got bent from hitting the piston I would presume......
Tommorow I'm going to install my crane adjustable vacuum advance unit. I have a dialback timing light and am well aware on how the duraspark distro works and can be setup by changing the advance slot and spring changes
Any thoughts
: :idea:
Later,
Doug
Any thoughts
Later,
Doug
