Here goes.
I had my PCV hose routed to the base of my air cleaner on my carb. I was told that was not the proper place for it and that I needed to figure out a way to properly feed it into the intake flow of air and fuel. I have an aussie head and right now my PCV is connected to the vacuum port on the intake manifold. I can't leave it there, because it will cause those two cyliners to run lean and burn up my valves.
My original thought was to drill a hole into my custom made Weber carb adapter and thread a hose fitting into it for the PCV hose. I am not too sure I want to be drillin' holes in perfectly good pieces of Aluminium, if you know what I mean. My Weber only has one vacuum port on it which is connected to the dizzy. So, I was thinking, could I run the PCV straight into the weber, through it's single vacuum port and run my dizzy and trans vacuum modulator off the intake manifold port? Please let me know if any of you see a problem with doing this.
Ted
Ted
