I am hoping that someone out there can point me in the right direction for this. Does anyone know if there is a tool or key made for removing the screw on housing for the fuel filter that is on the mechanical fuel pump that the 170 six uses? The top of the filter housing has 3 notches at 120 degree intervals, and looks like there is a tool or key that should fit on that for opening the canister for replacement of the filter element. The guy at the parts store today told me that they are not designed to be opened and that the element is not designed to be replaced. I know this not to be the case, but rather than argue with the guy, I bought the pump/filter assembly (which I needed anyway) and came back to the office.
IN the past I have used a strap wrench to remove the filter canister, with damage being caused to the canister as a result.
Is the tool available or am I going to have to see if I can find someone to fabricate one for me?
Thanks!
Thanks!
