torque.....what the...?
jeez, a guy akses a simple question & opens a size large can o worms....& I was just wonderin if a chrome muffler would make more torque or more horsepower....
Horsepower is an equation of torque.
HP = Torque X RPM / 5252
That is the formula. I learned it a while ago and it's very useful for making calculations in your head. :)
You can also use it backwards to find the amount of torque.
Torque = HP / RPM X 5252
You guys ever wonder why torque and HP curves generally come closer to each other around 5,200 RPM?
StrangeRanger":1vkeu0yp said:
That's EASY:
A nickel plated muffler increases torque
A chrome plated muffler increases horsepower.
Don't you read any tuner magazines?
:lol:
Dude, that's only true with stainless steel tailpipes. Or if you've got a 1/2" fuel line.
mikeyo":3ax3vc4e said:
Torque anybody? Here is some torque.
Here is an old bessemer cooper diesel that turns a backup generator at one of the hospital energy plants I work at.
6209 bhp at 400rpm.
Anybody know the math to get the torque rating?
Also neat: 15.5 in bor X 22 in stroke X 20 cyls.
doesn't that net about 83,000 CID?
I'd hate to pay for an oil change. :lol:
http://s94.photobucket.com/albums/l120/ ... engine.jpg
http://s94.photobucket.com/albums/l120/ ... ooper2.jpg
That engine is exactly 81524.17 ft lbs horsepower at 400 RPM.
For even more fun, ask some train guys about how much horsepower a locomotive has. :lol:
Here are some more fun things to consider...
The Electro-Motive 20-710G 2-cycle turbo-diesel has 20 cylinders each displacing 710 cubic inches, and makes
4150 hp @ 750 rpm,
4400 hp @ 800 rpm,
5000 hp @ 900 rpm (redline is 904 rpm).
It's turbocharger is geared with an override clutch, so at low speeds it's a supercharger, and at higher speeds it's a turbocharger.
Its piston pin is 6.5 inches in diameter, and a main bearing is 8.5 inches.
Oh, and 30,000 hours between overhauls (assuming operating at 80-90% load almost all the time.)
6209 bhp at 400rpm.
That engine is exactly 472.8865 horsepower at 400 RPM.
I calculated the torque to be 81524.17 ft lbs. from the supplied horsepower figure. I think you got the conversion backwards. :wink:
:oops: :oops: :oops:
That's funny, I think I just put it down because I forgot it was such a huge engine. I got the equation correct in the first post, but for some reason I did it wrong anyway. Go figure. :lol:
4150 hp @ 750 rpm,
4400 hp @ 800 rpm,
And the first gen Cummins came with between 160 and 235 HP.
Locos usually get measured in terms of tractive effort. Looking at this and adhesion factors will tell an engineer how much tonnage a train can pull for a given terrain.
Plus the new 3-phase AC motors on trains can take a -lot- more abuse than the DC motors. A truly impressive sight was a video of three EMD SD-70MACs taking an 18,000 ton unit coal train up an incline - 13,000+ hp and 600,000lb of tractive effort. Would not want to be near a coupler that let go!
Lots of very interesting advances in railroads right now...
