tri power, power gain?
yeah, the head is still rebuildable but needs someone who specializes in the 200 head, he said its a risk if he does it and id have to pay him, this was deffinently a hace head, if anyone thinks they can work with it let me know but im going to buy a guaranteed rebuildable head from martinez engine cores and have it rebuilt with the offy and bigger valves
my buddy told me that on v8 tri power, they block off the idle circuit and close the butterfly all the way, would this work on a six? sounds like it would cause vac leaks however it would keep the idle mixture from being too rich if it worked :hmmm:
Simple observation : Offy and most home-built tri's use the same Progressive linkage setup. The log head sixes flow requirements for drivability are low flow/light throttle with the outer "progressives" snapping wide-open at a tune-able throttle position. The outer carbs are typically shut down until needed. The center carb is typically higher flow and need to be tunable to compensate for outer vac/fuel idle-accel' transitions. (Balancing leaky outers to follow center/main carb is the trick)
Pics of Hillborn Injected and other radical early engines (car-porn 8) ) were mostly WOT tune specific - not very "drivable".
if i were to use the holley 1904's what venturi should i use for the secondaries, i have a small 60 style and a 61 style, im thinking the small one?
On factory V8 tri-powers the outer carbs have no idle mixture controls. The throttles are completely shut at idle and the engine idles only on the center carb.
