The real question is ...... WHY?
If you have the right trans and rear end gears, lag is NOT an issue.
You can get a single turbo set-up to run just fine. With all the crap needed to run 2 turbos in two stages (like the RX-7 did) you are asking for horrendous problems.
And one feeding the other is just a plain stupid idea. It's only for huge boost numbers like what the diesel tractor pullers run. You can blow up a gasoline engine EASILY with the boost from one turbo.
One guy I know in Tucson, AZ spent $12,000 building a completely new turbo set-up with staged turbos and it went slower than it did when it had one single turbo.
