kirkallen143
Howdy all,
Y'all have me foaming at the mouth over this turbo on a 200. Realistically, it seems to be a wonderous way to achieve HP, not only to look kool when you pop the hood. I will be another to turbocharge our small block ford sixes.
Now the set up:
1)Of course nothing in the extremes of drag racing or strip, just more power for all-out handling and pulling a load
2)Milled log to except direct mount 2-barrel, port/polish, 3 angle, larger 1.75 intake and 1.5 exhaust valves, mill head ('75) to obtain original 8.2 to 1 CR (that's with fel-pro gasket), and add port divider (anything I forgot?)
3)Use a TO3 (trim 50)? Want to spool up at 1500rpm and run out at 4500rpm.
4)Holley 2300 350cfm fuel source
5)blow through sys and no intercooler, yet
6)I am thinking in the 225HP range w/ this set-up
I am hoping to touch on the basics at least, for I am just starting (guess I need to buy a DIY turbo book). Well it's a start, what ya think?
Kirk ' 73 bronco
Now the set up:
Kirk ' 73 bronco
