Tatao,
Before I proceed much further, I wish to emphasize to you that a log head engine is not an ideal candidate for turbocharging, for reasons enumerated here and elsewhere. I am turbocharging mine to create a unique and fun car to drive -- that's all. I'll share what I know, have read, and am guessing at with the proviso that any persons modifying these engines from stock are doing so at their own risk and are completely responsible for what happens.
That having been said, let me get to your questions. From what you ask, I am guessing that you are new to turbocharging. If that is so, I can not over-emphasize the need to educate yourself somewhat before proceeding, especially if this car is your daily driver. You need to get and read Corky Bell's book
Maximum Boost. There are other turbocharging books out there, but Bell's book is aimed particularly at the DIY, budget minded shade tree mechanic working on old technology engines.
I think that a draw-thru system (suck through) is the way to go for one of these old engines. With a draw-thru system you don't have any electronics to worry about, no fuel pump issues, no hats, bonets, or carby enclosures to design, fabricate and troubleshoot. No return lines to the fuel tank. No expensive specialty carbs to buy. No intercooler to buy and install. A draw-thru also gives a nearly perfect fuel air distribution to each cylinder, because the compressor blades are mixing the fuel and air together at 60,000 to 100,000 revolutions per minute. Think of it as the ultimate blender...
You just have to provide oil to it (usually from a "T" at the oil pressure sender) and an oil drain-back line to the sump (see my top photo above). Rig your fuel line and throttle linkage, along with an air intake system and exhaust and you are nearly ready to go.
Now, it is true that we have restrictive intake and exhaust logs. But they are probably good for half a bar of boost. My aim is a 50% increase in power and torque from my system, and I think that's totally feasible.
Here's another website for you (
http://www.flash.net/~rjgeorge/tnotes.htm) This guy is the guru of these old pre-electronics GM turbo units, and between his website and the many links he offers, you can get a pretty good education on first-generation turbo systems.
Cheers!
