Got my rebuilt Q-jet today. It's the Buick turbo part number so it has the power system that's referenced to manifold vacuum/pressure. Plan to put a small check valve between manifold and carb so it'll read vacuum in the manifold, but not boost. I know from nothing about Q-jets, so I thought a professionally remanufactured one was best for me.
For a JY DIY project, it's getting expensive. Ordered an MSD 6-BTM yesterday. That's about all the hardware.
Now it's mock up time and fabricating some brackets and pipes.
I'll do pictures as I go.
Wish someone built an aluminum sheetmetal rocker cover for the 200. Looks like you could make the sides straight with welded in tubes for bolts. Make it a bit higher so it would clear everything--roller rockers, etc. You'd think I haven't spent enough money as it is.
