Twin turbo 300
Thats the plan because I can't find a machine shop to help me make it into a multi port intake.
If you have an old fence post, a drill press and a 17/32" reamer, you can do it yourself.
I used the original EFI fuel rail and just bent the injector cups to square them up.
There are several issues.
The hydraulic roller lifter is typically taller than the solid roller lifter because of the room needed for the plunger and oil valving.
This puts the connecting bar higher and interferes with the block bosses that the side cover bolts to.
This can be addressed by getting creative with a cross bar or clearancing the bosses or removing them and bolting the side cover some other way.
The Ford 429/460 retrofit hydraulic roller lifters have a spacing very close to the 300 six.
The 429/460 lifter bore spacing is 2.080". I'm not home at the moment to measure the 300 six lifter bore spacing.
The second thing to check is the lifter oil groove around the middle of the lifter body.
It must not go near the top of the lifter bore in the block at full lift with the cam you are going to use.
Open up the side of the main oil gallery so you can see the lifter body alignment.
With the lifter installed see where the lifter groove aligns with the oil gallery at the bottom and top of the lifter travel with the chosen cam.
Another concern is finding a distributor drive gear that is compatible with the billet steel cam gear.
The standard iron gear will not work.
The bronze gear will work but the gear wears fast which is ok for racing but not convenient for a street engine that sees mileage.
A composite gear is compatible and gives long gear life but would have to be a custom item. More research is needed.
There may be another type of steel gear that would work. More research again.
The 300 six use a 16 tooth gear that is not used on another engine V8 or otherwise.
The gear issue needs to be resolved first before ordering a roller cam and lifters.
So I'll be running solid roller lifters and a billet cam from Bullet for my 300 turbo build. The distributor gear issue is something I'd like to find more options on. Currently I just have the bronze gear comp offers, is there any "rough" mileage life these average? I'm not huge on the idea of having to change gears often if I use it as a street/strip driver. Does anyone know where to even put in a request for a composit gear?
Ask Bullet cams if a Melonized steel distributor gear is compatible with their billet cams
They said either bronze or composite, is there a place that offers melonized even? I didn't any luck finding anything but the bronze or iron versions anyway
May be better in the long run to go remote oil pump and some kind of cam /crank trigger and eliminate the dist. gear. I would be scared of a Composite gear.
Bullet cams can machine a camshaft gear to drive a different distributor gear from another engine.
The problem is still deciding on gear material.
The bronze gear gets changed at every oil change.
The composite gear teeth wear ok, but the thinner body can shatter at the hole for the pin.
The melonized steel gear is the strongest but there is some question as to compatibility with Bullet cams 8620 alloy steel gear.
I would be tempted to do what drag-200stang suggested and go to a remote oil pump.
Once you eliminate the load on the distributor gear the bronze gear will last if it is only turning the distributor.
I put a bronze gear on my 351W and it lasted about 2000 miles before the teeth failed.
I wonder if one of the manufacturers of distributor gears that make the stock gear also make ones for other engines with roller cams would be willing to make some for our group?
That is the Aussiespeed intake with the 4.9 fuel rail with the injector cups bent straight.
Would you happen to have a Clifford unit? I bought a Clifford because of the space limitations of the COE cab. It has small areas for nitrous. I would have to install injector bungs I need to know some dimensions of that intake. I might buy one of those.
And it's a D good looking piece for the long-stroke 300.
look them up at the Aussiespeed website. The distance from the head flange to the outer edge is 11 inches. It's wide. But the long runners will make better torque and more even distribution than Clifford or Offy IMO. Only the factory EFI intake will have better distribution, but if it won't fit in the doghouse, the Ausisspeed probably won't either. Personally, I would consider the doghouse modifications to allow the factory or Ausi manifold to fit. But boost makes up for a lot of intake deficiencies.
If you have a newer Clifford intake with the lumps on it for nitrous, you can drill and ream them for injectors as I did on the Aussie intake. As for the fuel rail, I bent the injector cups to 90 degree using a little heat and the but end of a 1/2" drill bit with tape on the end so it was a snug fit in the cup. You don't want to scratch the inside of the cups and have a fuel leak there. I'm using a throttle body off a 302.
The pads or lumps are very small/ shallow compared to your intake. How much power do you think the stock rail can support? I don't want to deal with pulse issues (pressure drops) and lean issues due to lack of volume in the small tubing.
I can't say how much HP the stock fuel rail will handle, but there are lots of examples of it being used on the stock intake with turbo applications. As the fuel pressure on these engines is higher than most applications, I'd be surprised if the fuel rail was the weak link in the system. If you're doing a intake where the injectors are perpendicular, then it's easy to make-up a fuel rail with readily available aluminum fuel rail extrusion.
The factory one will hit at the back because it's wide all the way across. Thanx for pointing out measurements on the website. I'll look and compare it to the Clifford. I might have to make a styrofoam mock up of the ausie one to check its fit. I'd rather not cut into the floor towards the passenger side. It will get into the heater box and the legs of the passenger side. The doghouse cover will have to be custom to clear the valve cover and intake.
Ok I have been calling around for some time off and on. Distributor gears for a roller cam other than cast and bronze for the 300. Called Comp, MSD, DUI and other Distributors that are being advertised on eBay. One says its a steel gear but they don't know so gave me the manufacturer and I called them. I don't think they manufacturer them either.....they can't tell me what grade of steel. I have done some searching around and see that there maybe be an early tooth count of 15 and newer count of 16. Are all years .530 shaft size? I contacted a heat treat company in Phoenix. They want $500 to heat treat and Melonize a steel gear. He recommended 4140 for the gear material if I had one made locally. Does anyone have any info on different year shaft sizes and gear counts?
