Ok, I've been hearing some knocking lately and seemed to cure it with premium gas ($$). But on my way home from a 60 or 70 mile trip, it started missing a bit on the highway at about 70 MPH. When I pulled off to check it out it was running worse and worse the slower I went. It sounds like a diesel!
The plugs look ok. # 3 and 4 are a little fouled, but not seriously. I've just now put the points back in thinking it was the Pertronix going bad, but there is no change. Timing is good at about 12º BTDC. Changing the timing didn't seem to help the idle at all.
Any ideas?? The car is a 65 Mustang 200 with a stock 1100 and distributor.
Thanks,
Scott
Thanks,
Scott
