Hi, I have a 200 with the universal carb. When it is warmed up it is hard to start and floods. It ran OK until I put the larger original air cleaner on it and hooked up the heater hose to the carb base. Any ideas? Thanks
First thing I would check is your needle and seat for wear next is the float level setting. Both of these if not right can cause the symptoms you describe. Good luck
