You don't have it seated all the way, and if you try to bolt the tranny up you'll ruin the front pump, or worse!Goatbarron":110qv2qf said:well, ill put it on and it will just spin around then it will slide in some and then stop again, it will spin and feel like its spining one of the shafts, but it wont go in any father, and weve spun it sround very slowly pushing it in and it wont go in at all, any ideas
You should feel two definite clunks as the converter seats onto the input shaft and the flats of the front pump shaft. You need to lift up, and turn the converter while pushing forward at the same time. When it seats fully, it will make a solid "thunk" noise. Be patient!!!
