1981 Capri
Is there any advantage or disadvantage in V belt length .   I have a 200cid  . The alternator adjustment bracket could have  a lot of  possible V belt lengths .    If i put on the longest V belt that the alternator adjustment bracket would fit , does this have more belt around the alternator pulley ?  is there any advantage to a longer belt ?     Or could  go with a shorter V belt and bring the alternator closer to the engine .
The different V belt lengths would both have the same belt tension .
There is lots of room , is there an advantage to a longer alternator adjustment bracket and move the alternator further away from the engine ?
