with our beloved Ford 6's ( and most fords pre 57 ) a venturi vacuum was used , why , because there was no mechanical advance in the dist just a breaker plate that moved with the help of a vacuum source that got stronger as the carb was opened , a good ideal , NO but it was cheap and for its time was adequate for everyday STOCK USAGE !! , in 67 ( 57 for most of the v-8s , ford upgraded thier dists with mechanical advance and vacuum became an Econimizer addition in our Falcon 6's just as it had been in most previous combos , including the Big three automakers, However to say that it was only for emmisions is a misinformed statement that I have seen posted here many times, between 1957-and 1966 emission controls ( with a few exceptions wer non existent ) but ported vacuum WAS the Norm , now after Emissions cam into play was Ported vacuum used to help emmissions , yes but only because electronic controls were years off , Curves in Distributers are complex not all encompising as some on this board ( and many other places ) seem to state , I recurve Dist's as a side business , have since 1986 , and previously to that for othe employers ,bending tabs , adding springs of different tension are part of the equation BUT , only part. limiting or adding more initial advance , limiting or adding vacuum applied advance is also included , AND KNOWING WHY , not just how is a years of experence that cant be expressed enough , if you blindly go forward with only the tools and an instruction sheet / advice to go by, you are assuming the knowing WHY parts is not important , and that is a mistake that can be expensive
