All Small Six Vacuum advance canister
gserafini
Subscriber
I think I need a new vac advance canister. 66’ 200, California car, LOD distributor with Autolite 1100 and SCV. My vac advance isn’t working. Put the hose to it and sucked air from it, I can hear air pull through and nothing turns in distributor. Then I tried again and the plates did move in springs, but I had to use some force and could feel air pulling through too. Seems like a leak in the canister. At least my plates are moving if I get the seal right. But what part number for this vacuum advance?? A lot are for v8 engines or don’t say for the 200 i6 load o matic specifically. Thanks!
Hi, I just did a Google search and CJ Pony parts has them in stock. Good luck
Get rid of the LOD distributor and carb and run a non Cal set up if you can.
Thats the plan, probably next year. Just trying to keep it driving for the summer. It is a Ca car, but the thermactor had already been removed when I got the car. Which has brought up a lot of questions about the timing and curve of the dist, etc that's hard to find information on, haha!
Don’t forget you can get all the distributor help from Ambler Racing in the vendor section of this site. He can get you set up😎
