That's better. No matter what, every time the vacuum spikes from low to high- like every gear shift, or decelerating- oily vapor is shot toward every far-end of the system.
It's a fluid dynamic characteristic- when vacuum increases in an airmass with heavy particulates, the particulates are drawn in the opposite direction of the vacuum source, and toward the walls of the constraining tube.
A good visual of this principle is the windshield repair kits. Some glue is put on a crack, and a suction cup applies vacuum. Logic would say the vacuum would draw the glue toward the vacuum cup. In reality, the vacuum causes the glue to move to the farthest, deepest recesses of the crack.
It will take a while for blow by residue to affect the modulator valve and brake booster, but don't doubt it's getting in there, because it is. The closer to the intake the blow by can enter it, the less of that oil air is available in the hose to activate the booster/modulator.
Probably overkill, I always isolate PCV from everything else. Even when, in one case, I had to buy a carb spacer and drill/fab a port in it for PCV and use the intake port for the rest.
