No, the Weber 34 is a very simple single barrel carb, and it uses its own set of air correctors and jets.
Its a very unlike the 2-bbl Holley Weber and Weber 32/36 carb. These Pinto/Capri/K-car/Vega carbs are far more plentifull, but have heaps of little differences, with something like 9 different versions from 1969 to 1975 alone.
I think the 34 Weber was used as a replacement carb for VW Bugs, some Opels. Normally Offenhauser, Clifford or Pearce supply jetting tips as part of the package. If you do a search, there is some information on these set ups, on this forum. It will take quite some time searching for it, but its apparently a very easy carb to calibrate.
