What Cam are you turbo people using? Do you like it?
I too have the S-292 and I agree and disagree with does 10's although I have a 5 speed trans, I am having trouble tuning it, it has very low vacuum which is the cause of the transition problem, I'm thinking fuel injection would make this cam better, now I have to say I love the power...
Does anyone think these would be good custom specifications for a turbo cam?200 ci with aluminum head, 1.6 rollers, portwork.
Adv dur.......@.50.......lift@ 1.6.......lobe center
278/272.......228/222....480...........110 degree
Bump up the LC to 112-114 and you should be good.
Those cam specs are very close to what we had made.
I just don't know yet how it'll work!
Will
Here's the new 278/272-114* profile Will mentioned.
I don't know why he wanted it that way either. But that's what he asked for, so that's what we made for him. Personally, I would have went with a 278/278 single pattern cam, but we'll see how this works out.
Yea, I am curious. I need a good turbo cam. Still open to recommendations.
Bort62":1srr4m9e said:
Ha! a dual pattern w/ more intake lift and duration than exhaust... that's somewhat unconventional.
Doesn't it make sense though? Since the air is being pushed in instead of pulled in? . . .
Mike,
I assume that's my cam card?
Well those number aren't exactly what George at Clay Smith and I talked about but they are very close. So I'll take it! The end result should be the same.
My reasoning.....intake reversion with a turbo and restrictive exhaust.
The cam we were using was Mike's 292 cam. This cam has a bunch of valve overlap. This would be great for a high winding N/A, or nitrous motor. Maybe even a supercharger. But the exhaust system needs to be very unrestrictive. Turbo motors (ours in peticular) has a fairly restrictive exhaust due to the turbo and header.
With the 292 cam the exhuast restriction (backpressure) will not allow the intake charge to fill the cyl. until the boost pressure is at or greater than the exhaust.
Kelly's Falcon acted horrible until it came up on boost, then it went great. Driving around town was an art form!
With our old 274 cam it left pretty hard. 1.6-1.7 60' times. The best we could get out of the 292 cam was 1.8-1.9. And that was after I increased the valve lash to reduce the cam duration. When I used the recommended lash the 60's would be in the 2.0 range. So we lost around .3 seconds just at the 60' mark! That's a huge difference! What's the rule....1 tenth at 60' is 2 tenths at the top end! Last time out she ran an 11.69@123.77. Her best ever MPH is 124. But the ET is way off.
So all we need to do is get the car to leave and we're in the mid 10s!
BTW...Don't get me wrong, I'm not bashing the 292 cam. It's just not the right one for our application.
So I'm either going to be a Hero or a Zero! But like Bort62 said it'll at least make for a good data point! Or Kelly's going to run 10.50s!
I'll definitely post up when we get a few passes on it.
Later,
Will
That is an interesting point will about reversion & overlap.
I still don't understand why that led you to have a higher intake duration and lift than exhaust, but thats okay.
Let's see how she runs :)
