I have a serious compression ratio problem with a 2V Oz head on a 250 block. The head has been agressively milled and with a solid copper head gasket .060 thick,still, results in a 14 to 1 compression ratio. The desired ratio is more, like 8.5 to 1. I have several options available to achieve 8.5 to 1 but I am concerned about quench, flame travel etc. The combination of options under consideration are; enlarge the combustion chamber and unshroud the intake valve, which adds 30cc's, dish the piston 30cc's, build in a negative deck clearance of 30cc's, I need some combination of these or other solutions that add approximately 40 to 50 cc's to the combustion chamber volume, The current volume is 54cc's and the engine will be turboed to a maximum of 17 -19 pounds of boost.
Any help, ideas, creative insights , or strokes of genius will be greatly asppreciated. Another unmilled head with a 62cc chamber will only give me 11cc's more.
Thanks!
Thanks!
