After some research I'm leaning towards this motor being a 200, but not all the details make sense.
I bought it thinking it was a 170. It's for my 62 Econoline and I was leaning towards the 170 as I'm mostly concerned about efficiency over power, but I'm still happy if its a 200.
The block casting code is 11 C8DE 6015-A. Which is the code for a 68 200. What doesn't make sense is that the motor has three freeze plugs. Also it is drilled for both the 8.5" and the 9" bellhousing. It was my understanding that some early 200's only had three freeze plugs, but that none of these early 200's were dual bolt pattern.
This motor is replacing my 144. I was planning on using the Holley 1904 that I already have on this motor, but I'm concerned it may be to little for the 200. Also this motor has a head on it from 75, so the carb mounting bolt spacing is larger than the previous motor. Are there adapters avaialable? Is it worth it or should I just find a new carb? If so what carb should I start looking for that will work with a vacuum advance distributor and will give me the best mpg?
