what should i run
what should i run with my tri- power
  • 1. holley glass bowl
    Votes: 4 36.4%
  • 2. autolite 1100
    Votes: 4 36.4%
  • 3. carter yf
    Votes: 3 27.3%
  • Total voters
    11
help me out, i have 2 glass bowl style holleys and 2 autolite 1100. i might trade them for some carter yf's depending on which would work best :nod:
If you have an older small log head and manifold you might want to stay with the Autolite or glass bowl Holley. If you have the big log head you could use than make use of the later model Holley's or YF Carter’s. With a little work you could make them all work good. :thumbup: If you decide not to go with the old glass bowls I could put them to good use on my 54 Customline. :nod:
they are not the glass bowls but they are the same design and need some work, one has a larger venturi, i would trade them both for an autolite 1100
As long as one would match up with the 54's stock Holley (also not a glass bowl) that would be the right one to fit on my Offy 2x1 intake though :nod: . Ok great will look too see if I still have an 1100 left or can find one.
or if you have 2 of any matching 1 bbl let me know, i have 5 carbs all together, i have 2 glass bowl type with metal bowl,( 2 autolite 1100, one rebuilt, one broken lever ), and one holley 1940, if you can get me 2 of the same carb, you can have all of these
all would do fine im sure, especially on larger log. i myself plan on running 3 carter yf's on my build since i have quite a collection of them :mrgreen:
I'm running
3 weber 34 ICH carbs from CB Performance. Didn't need the choke on the center
. IICRC $150.00 each brand new.
i think ill just get some yf's or 1100 for now just to get it running and try the webers later, whatever gives me the best performance, i dont care about gas milage, just wana burn some rice :lol:
yea i have spares. heres the 1 barrels i have
-5 carter yf's (and 2 more on my cars)
-1 carter rbs
-1 autolite 1100
-the yf's i have are 195cfm rated i believe.
