64 inboard
Been a while since Ive posted. Ive got a 64 Correct Craft boat with a 170 six. The oil pressure has been doing some funky things. On cold start it reads 35-40 lbs. After warm up, while cruising around 2-2200 R's, it s dropped to around 5lbs. (and yes, it has oil) It will occasionaly, for what appears to be no reason, go back up to the 35-40 range, only to have it drop back down again. Not sure, but my thoughts are , worn oil pump or dirty/plugged pickup screen?
Earlier this spring I ran a comppression test (not related to this, just doing a tune-up) . The manual shows it should have 160 lbs.(really?) Im running 130 even, within a lb or two, across the board. I know this isnt related to oil problem, but wondered if the 130's normal?
