OK, my TDC's were all muffed up. I found TDC (true TDC), marked the dampner accordingly, and proceded to set the timing so that the new TDC mark was right around 10deg before TDC (toward the passenger side of TDC on the pointer)...right?
WOW. What a difference. THAT's a bit more like she should be running.
I'm still confused a bit though...i always thought that as you turn the dizzie, if the idle goes UP that's more advance and as it goes down, that's less advance...no? BEcause as I turn the dizzie to get it to what I thought now to be BTDC according to the above info,the idle is dropping, as I pass 10deg BTDC the idle stops dropping as rapidly. As I turn it the otherway, moving now to what based on the above would be more retarded, the idle goes up.
: WTF?? Can that be related or coincidence?
Now, i have two (or 10) more questions:
1. which vacum port on the carb should i have the dizzie attached to? I've got the Holley 2300 500CFM. There is a port sticking out from the base of the carb that pulls about 20 HG's of vac at idle (idle is a bit high) and there is one just above that level that pulls less than 5HG at itle but shoots up with throttle. There also is the really large one at the back of the carb which I think is for brake booster or PCV right? I set the timing with no vac line attached and currently have the dizzie hooked on the one pulling 5HG's
2. now I hear what I would attribute to lifter tapping. Do I need to readjust my roller rockers now that my timing is different (and right) or am I hearing pinging? How do I correct it? I tried backing the dizzie off more toward retarded (moving the dampner marks more toward the driver's side)
3. I've got some white spoke coming from my valve cover caps...was dat?
Thanks agian tons all!
OH YEAH! Here is the kicker. Since the rebuild, I have NOT been able to use my ignition switch. Turn the key and NADA. I've been using a remote starter. Well, after adjusting my timing, now all of a sudden my ignition switch works again.
