The Search Function is my friend
Oh the search function is my friend
The '40 and the '46 , the search function is my friend.
1.
http://www.albertpenello.com/mustang/engine.html
2. Wed Jan 07, 2004,
https://fordsix.com/forum/viewtopic.php?f=11&t=11031
Listed in the Ford Six as 195 cfm.
At 1.84"Hg or 25 " H20, a 2-bbl DGAS Holley Weber or 5200 Holley Weber flows 227 cfm, way up on the meager 156 cfm the Holley 1946 flows at that pressure drop.
Rated at 3" Hg, the 1946 flows 200 cfm
3. 07-02-2012, 11:16 PM
http://vb.foureyedpride.com/showthread.php?t=134603
4. 1945 Chrysler 225 1-bbl carb is similar, was incorrectly quoted as flowing 170 cfm at 3.0" Hg, but the Mopar air horn and intake is better engineered and less restrictive.
http://www.rasoenterprises.com/index.ph ... arburetion
5.The HP Holley book printed in 1976 says the Mopar 225 Holley 1945 came in one size with 1-11/16" throttle bores and flowed 203 cfm @ 3" hg.
http://www.slantsix.org/forum/viewtopic ... bc05ea73a5
6.
http://classicbroncos.com/forums/showth ... p?t=175726
The Ford Motorcraft Part DOPF-K Autolite 1100 replacement was the Holley 1940 List # 4529 for 200 cid engines, and it flows somewhere between the around 170 cfm and 187 cfm since its a one size fits all replacement approved by Ford as an Autolite 1100 stand in.
The 144 ThriftPower Six had a 1.00 Venturi 120 CFM carb
The 170 ThriftPower Six had a 1.100 Venturi 150 CFM carb
The 200, 250 Six, a 1.20 Venturi 185 CFM carb
The 1940 was a one size fits all 200 replacement, probably about 180 cfm
http://www.youtube.com/watch?v=CzHc0BKexlI
