Which T/O bearing to use 2.77 to 3.03 swap?
bob emmerich
Active member
Haven't posted in ages, however I do check in from time to time. I have a 64 170 engine and I'm going to do the swap from a 2.77 to a 3.03 3 speed. I am having trouble finding the right T/O bearing.
I cannot use the 2.77 on the 3.03 for obvious reasons(bigger shaft housing). Is there a different year T/O bearing I should use, or should I use the 66 V-8 10" clutch bearing? I already ahve the adapter plate to match the 5 bolt bell, so this is the only thing holding me up with putting the engine/tranny back in.
Thanks. Bob
Go to the tech section and into Al's swap info. As I recall he has most of the info for that there. J
