robert_t_wallace
I'll try to make a long story short.. Had a rear main seal leaking and hired a mechanic to come over and do the work. While doing the seal, he noticed that the timing chain needed replacing. He did the seal and replaced the timing chain, but ran out of light so stopped. 16 degree weather hit so car sat with timing cover off and radiator hoses open. After it warmed up, came out and finished the job. Running the car, it started smoking, oil was milky and car over heated. We went in and replaced head gasket... same thing.. Mechanic is saying I need to get the head checked..
I know coolant passes through timing cover... but... I am getting lots of white smoke which indicates coolant in cylinder.. I was thinking bad gasket on the timing cover.. I am hoping it's not a cracked block..
I did find a 1973 Maverick inline 6 on CL.. I assume that would be a drop in??
My 200ci is the original motor in a 1966 Mustang coupe. It has the Clifford 2bbl conversion with a Weber carb. It also has the classic inline split headers..new,alternator, new water pump, new timing chain, new starter, pertronix in the original dizzy...
