This is something that given good advice, shouldn't be one page deep to fix.
1.What's your fuel consumption like with the 32/36 Weber? I've found that the stock 4-cylinder emuslsion tubes can cause a rich idle, rich enough to create a blue ploom behind a vehcile.
2. Is your car likely to have had a freeze/thaw situation where a hairline stream crack is formed. This is real common on US thinwall Ford blocks seeing as some parts of the US (due to altitude/climate) can swing from negative 30 degrees F to 100 in 24 hours. Just one cycle can result in No 1 cylinder hairline cracking, causing permanent damage that is unable to be conclusively determined.
You should check the obvious first, though,
1.Find a shop which will run a hydocarbon gas indicator sensor in upper radiator tank, std check for a blown head gasket
2. 24 static leakdown. 24 hrs, not a couple. If they don't, do one yourself using a PVC pipe water tester such as Mico pipes or Ingersol Rand make for the contracting industry. Pressurise to 6psi, but Instead of water, use kerosene, and measure leakdown over 4 hours after an 8 hour cool down. You need a stock spark plug insert adaptor so you can put a scew in union into the spark plug. Flow rates for kero are sky high. You'll have to grab some gear from home depot, but here are some examples of the 2-stroke ones
http://www.thumpertalk.com/topic/691117 ... end-power/
http://www.thumpertalk.com/topic/432226 ... -2-stroke/
If there is a great loss in pressure compared to other cylinders, then the crancase will need an oil change. The cylinder should be filled carefully with about 632 mililiters of kero at bottom dead centre, and at all times, turned only via a 3/4 scoket and inch prybar. Kero is danagerous projectile under pressure, and just a degree of turn will drive out a bunch of it. There is the option of loading up the No 1 cylinder via hand wit the pry bar, and then locking it with a log of 2 by 4 jacked with a non hydralic Toyota car jack. Then do2, 3, 4, 5 and 6.
Last option. Well, over here, a Falcon head gasket is like $33 NZ for one Monotorque 41 thou composite AFF630 which Ford Australia stocks for all 200/221/250 log and 2v headed Frauds. So its reall easy to undo the cylinder head and exhast manifold and wack in another an see if it fixes the problem.
You can't ask a page of info, and not get the hel[p yopu need, brother. We want you to get the white or blue smoke gone! but your gonna have to do something different to what you've done. Some small detail not covered is the problem, and the problem is simple to diagnose
