TucsonHooligan
Ok, so it's still smoking, but about 75 percent less now. I pulled the main jet and its a 55. Too big or what? Two jets up top are 180 for the primary, 195 for the secondary. So what direction should I head?
TucsonHooligan":7y7kr6d3 said:it's still smoking, but about 75 percent less now
TucsonHooligan":25fgar2e said:give it a little more juice
Darn good idea, but he states that the pcv is not the issue.I pulled the valve cover and the seals look good. The block was zero decked and the head shaved for compression. Gonna try the drizzling oil technique, see if that yields any results. PCV system isn't the issue, as I pulled it and plugged the vacuum with no change in smoke.
All the short block machining was done by a reputable machine shop that has been used by numerous friends with top notch results and is owned by a builder/racer, so I'm thinking the weak spot in the build is yours truly. I'm still gonna exhaust all other options before I get drastic tho...
EDIT: Tried the drizzle down test, no visible change in smoke. There is an awful lot comin from the rocker assembly area though, kind of filled the engine bay a little. That a clue to anything?
