I will not know until I call....
This is the P# for them... 50565CP .040 the price on them was 36.00
actually, I am going to copy you their parts invoice... there may be some clues in here.... I am wondering about the rod bolts and rings... they are supposed to be ARP bolts and Moly rings... per my instructions.
Rod Bolts CRB640 23.76
Rod Nuts CRN610 3.96
Head Bolts HAP30605 59.36
Washers APW1316 16.80
Valves were from SI industries and I bought those.... 145.00 stainless
Pistons 275P .040
Rings 50565CP 36.13
Rod Bearings CB583P .010 39.30
Main Bearings MS771G 91.69
CAM Bearins SH703S 20.71
Plugs PE105R 6.95
Retainers RE 65.40
Springs 903-12 62.96
Keepers 601-16 8.80
Rods 7974-16 166.45
Here is the labor...
Polish Crank Already .010-.010 30.00
Rework Seats, Surface, PT ,Install Guides and New Valves 225.00
Surface Intake and Exhaust Surfaces 135.00
Bore & Hone Block 0 Deck-Install Cam Bearings and Plugs 245.00
Recondition Rods & Press Pistons Off & On (New ARP Bolts) 150.00
Balance Engine 150.00
Port Head 125.00
Rebuild Engine Long Block - Fit Rocker Arm Assembly abd Drill Head 350.00
Weld Divider 65.00
That is my WO....
Grand Total was 2466.04
908 parts / 1475.00 labor
I am posting this becasue it may shed some light on a few things, and maybe someone can see if I got taken, or jipped, although I felt pretty good about the work... it may be something small or not? If it is something in the machine work then I have a warranty...
Pistons 275P .040
Rings 50565CP 36.13
Plugs PE105R 6.95
Retainers RE 65.40
Keepers 601-16 8.80
Rods 7974-16 166.45
Port Head 125.00
Weld Divider 65.00
That is my WO....
