WhitePony - Sorry to rain on your parade but that shroud won't work. You arn't actually pulling more air with a shroud when your fan is attached to the radiator. Shrouds are used when the fan is far enough from the radiator to pull air from the engine compartment instead of through the radiator. Also that much shroud will block air running down the road.
This is a subject debated a lot in flathead Vee-Eight groups. In a flathead the exhaust passages run for about six inches though the water passages, thus cooling becomes interesting (and why you can run a healthy overhead valve eight behind a stock flathead radiator). What you really want is a fan that pulls air like crazy when the car is not moving, and pretty much disappears when you get moving. Remember that a large fan is an obstruction to air flow when you are going down the road too. My father's '47 Ford pickup would cool nicely in 105 degree weather with a big four blade fan and a shroud, below 50 m.p.h. Get rid of the fan and shroud and it would cool above 30 m.p.h. but overheat running slower than that. The fan was about three inches from the radiator. The only flathead we have had that would cool all the time, no matter what, was a '41 pickup with a big six blade fan positioned about 1/4 inch from the radiator. The conclusion to this (too long?) story is that you need the biggest electric fan you can fit in your car, run off a thermostate, and ditch the water pump driven fan.
