xflow head
Hi I was wondering if someone can give info. I,ve just bought a head its been ported and has non adjustable roller rockers. I think the head has been shaved , will I need shorter push rods? I,m building up a motor with new cam, lifters etc to put in my 89 ute. Probably to run straight gas.
if u get a re-ground cam then some times they knock a bit of the back of it and with youre head shaving and what not it can work out good.
BUt you can buy shim kits from crain they go under the rockers this way you can get yore preeload correct
