yella terra rockers
angier6stang
okay, after reading a few, I had the YT rockers installed and didn't know about the oiling issues. what to do now the engine is built and in the car? I don't want to waste what's in there...... rockers, cam, and DUI, before getting it going. :shock:
Since you have it all assembled, just look for an oil leak at the left rear of the engine at the head gasket.
If you develop a leak & pull the head plug the oil pressure passage in the block.
Also to get more oiling to the distributor gear, grind a small flat in #2 & #3 lifters at the top to the oil annulus on those 2 lifters. They will then supply extra oiling to the distributor gear. Bill
Bill, do you have a picture of the modified lifters you can post? Mine is together but not installed and I might pull the head to make the change.
Scot in OKC
