Put kit in YF and no change from before.
Idles nicely and gentle acceleration of throttle for 1/4-3/8" causes no issues, but if you hit it there is a huge flat spot then lots of sputtering...
Big thing I did notice: no "shot" into venturi from accel pump.
(old and new pump diapraghms were fine)
Q: No shot would cause a huge flat spot, correct?
I took the top off the carb and watched the accel pump action.
Fuel shot comes up the vertical passage in float bowl wall past the "needle valve" to the top of bowl where it is sealed by gasket.
I put my finger on top of the passage to act as the gasket seal, and the pump shot bleeds back into the float bowl and nothing goes into the venturi! There is what looks like a nozzle into the venturi right at top of the "pump passage" where the bleed port into the float bowl is.
Q: Is this "nozzle" where the "shot" enters the venturi?
If that is the nozzle, it is blocked somehow.
I twisted about 8-10 threads of wire together and tried to push them through, they "hit" something and bent. What could be in there?
