wsa111":1qx0ytle said:
			The big question is performance distributors machining the housing to a different demension so a gasket must be used???
Seems you are missing the point. A gasket must be used with
ANY distributor, not just the DUI. The illustrations in the Master Parts Catalog show the gasket being used on both the Load-O-Matic and the Duraspark distributors. Both distributors, as well as the DUI, were designed to use an O-ring and a gasket.
I seriously doubt that Ford (with all their wisdom and extreme foresight) designed and produced a distributor base gasket and included it in all their illustrations, just so some company which didn't even exist back in 1960, could say it needs to be installed when their customers complained about oil leaks.
However you are correct about Distributor Shaft End-play. It is extremely critical and should be checked whenever ANY new distributor is installed, not just a DUI. Doesn't matter if it's a rebuilt LOM or DSII, a Mallory or a DUI, it needs to be verified. However, I also doubt that 1 out of 20 (if that) actually check the end-play. Most just stab and go, assuming it's correct.
Bottom line, when ever you install a new or rebuilt distributor,
regardless of which distributor you use, you should use a distributor base gasket, verify the distributor shaft end-play, and break in the new gear accordingly.
