DUI - flat gasket to block or o-ring?
62Ranchero200
Post #1 by 62Ranchero200 » Thu Mar 20, 2014 9:07 am
Greetings Ford Six Fans,
I purchased my DUI many months ago for my old 200, but never had a chance to install it before I realized that the 200 needed to be rebuilt or replaced. Now I want to use the DUI with the new 250, and I'm ready to install it.
It's been so long since I purchased the DUI that I can't remember - does it use a flat gasket between the distributor body and the block? Or just an o-ring that seats into a groove? I can't find a gasket anywhere. I can't find a flat gasket at any auto parts web site, but I have seen O-rings. If it does require a flat gasket, I'll have to either get another one from Performance Distributors, or make one from gasket material.
Bob
62 Ranchero, 252 cid, 300 rods, RaceTek pstns, ARP mains bolts & studs, balanced & blueprinted, CI AL head, 1.6 adj rckrs, Smith Bros, 274/274/108 cam, CI int, Holley 500, DSII, CI SS hdrs, PowerMaster strtr and 1wire alt, Optima, V8 rad, T-5z, 10" organic clutch, 5 lug 8" w/3.80 Trac Loc, rear drums, front 5 lug discs, Centerlines. Next: ?.
wsa111
FSP Moderator
Re: DUI - flat gasket to block or o-ring?
Post #2 by wsa111 » Thu Mar 20, 2014 9:57 am
Bob, o'ring should be already on the housing of the distributor.
Before installation lube the housing area & o'ring area. Also put heavy oil or moly lube on the distributor gear to make sure no wear occurs on a dry start.
64falconsix
Post #3 by 64falconsix » Mon Mar 31, 2014 8:42 am
O ring.... the one that came with mine was too thick.... pick up another at ace hardware. 3,000 leak free moles so far.
64 falcon 2dr 200 C.I. .040 decked ,comp. 260 .440, C.I. adjustable timing chain w/ 79 log head 52.cc , offy w/ triple webers , Clifford header , D.U.I. , C/4 2,200 stall , Transgo Stage 2 reprogramming kit , 7 1/4" with 3.20 gears. NX, N2O 75HP shot.
10.29@ 61.91 M.P.H. in the 1/8th mile. 4/12/13
Users browsing this forum: No registered users and 9 guests
