falcon_master
Hi everyone. So I've finally gotten around to my falcon again and I had it be able to actually start up last time I worked on it a little bit ago. Well today I put in the key and turn it and nothing. The solenoid is dead I remembered so I bypassed it and the engine will crank over but won't start up not even with starting fluid. I traced the problem to what I think is spark. If it does have one it's so weak I can't even see it. What can I do to diagnose what part if the ignition system it is. Distributor or the coil. Could it even be the ignition switch cause it won't work for start maybe it's not working for ignition thanks everyone
